Cada vez tengo mas dudas de cual será mi próxima guitarra ( la comprare en navidad ). Y ahora estoy entre estas. Mi sonido se ha ido definiendo hacia un rock mas clasico pero moderno , no se si me explico ( FOO FIGHTERS, BLACK KEYS, JACK WHITE ..... )
SOY ZURDO
TOKAI ALC 60 L
BODY : Basswood
NECK : Maple Set-Neck
FINGERBOARD : Rosewood
FRETS : 22F
BRIDGE : LS-VBC Bridge
/LS-VTC Tailpiece
INLAY : Block
PICKUPS : LSC-F×2
CONTROLS : 2V.,2T.,3way Toggle SW.
PRECIO ---> 470€ sin estuche y 500€ con estuche duro
Dillion Pheonix, the Dillion DFB603RX Guitar
http://www.youtube.com/watch?v=-nB-2-7rm_k
Solid Mahogany body
Bound set neck with striped ebony fingerboard
plus Matching headstock
Grover USA gears with 18 to 1 ratio
White Pearl large block inlays
22 hand polished 2.9 mm jumbo frets
Bone nut + D'Addario strings ( 10-46 )
Dillion custom bridge
Three Dillion vintage humbucking pickups
3 volume, 1 tone, plus 3 way switch
12" Radius
24 3/4 scale
1 11/16 nut width
Imagen no disponible
http://www.adirondackguitar.com/lefty/dillion/fb.htm
PRECIO ---> 540 CON GIGBACK ( LE PONDRIA BIGSBY MAS ADELANTE )
Gretsch G5435LH Pro Jet Black
Gretsch G5435LH Pro Jet Black lefthand e-guitar, electromatic Series, LP-Style, basswood body, arched maple top, chambered body, set thomann maple neck, rosewood fretboard, pearloid hump- Block inlays, 22 medium frets, nut width 43mm, scale 625mm, 2 Black Top Filter´Tron pickups, 2 volume-, master volume-, master tonecontrol, anchored adjusto-matic bridge, G arrow knops, white pearl pickguard, finish black
http://www.gretschguitars.com/products/index.php?partno=2517210506
PRECIO---> 400€, LE PONDRIA UN BIGSBY MAS ADELANTE.
Fender Standard Strat MN AWT LH ( FENDER MEXICO )
Fender Standard Strat MN AWT LH, e-guitar, Mexiko, lefthand, alder body, maple neck (modern C-shape), highgloss finish, 648 thomann mm scale, maple fretboard, 21 medium frets, nut width: 42,0 mm, 3x standard single coil pickups, 5-way toggle, vintage-style synchronized tremolo, 3-ply parchment pickguard, colour: arctic white
https://www.thomann.de/es/fender_standard_strat_2011_mn_awt_lh.htm
PRECIO --> 490
Fender Std Telecaster LH MN BSB (TELE MEXICO)
Fender Standard Telecaster LH MN BSB Electric Guitar - left-handed, made in Mexico, alder body, maple neck (modern thomann C-shape), highgloss finish, maple fretboard, 21 medium frets, 2 Hot Standard Tele single coil pickups, 3-way switch, strings-thru-body bridge, 3-ply parchment pickguard, 648mm scale, 42mm nut width, vintage styling, Colour: Brown Sunburst
https://www.thomann.de/es/fender_stdtelecaster_lh_mn_bsb2011.htm
PRECIO --> 530
Ahora bien, no puedo probar practicamente nnguna de estas guitarras, ya que no las tienen que yo sepa en ninguna tienda de madrid
Sería mi segunda guitarra, la qe tengo ahora es una Squier strato affinity de 130€ y me gustaría notar diferencia.
Saludos y gracias amigos.
SOY ZURDO
TOKAI ALC 60 L
BODY : Basswood
FRETS : 22F
/LS-VTC Tailpiece
INLAY : Block
PICKUPS : LSC-F×2
Solid Mahogany body
12" Radius
24 3/4 scale
1 11/16 nut width
PRECIO --> 490
PRECIO --> 530
