Para identificarla seria importante saber si los inlays son puntos, o tiene coronas, bloques o algun otro inlay mas curioso.
¿Algun link de donde la has visto?
Mmmmm... solo sé que no son puntos. No hay fotos porque la he visto in person un rato nada más. Ya sé que con tan poca información es una lotería. Lo que me ha despistado es que en la pala no ponga nada más que Epiphone.
(¿Te valieron los cabezapollo?)
The Epiphone version of the famous Oxblood Les Paul.
The Limited Edition Epiphone 1954 Les Paul Standard Electric Guitar has a maple top with a solid mahogany body. The oxblood finish is a deep chocolate-brown color that shows some oxblood tints in certain light. The guitar's set mahogany neck has a comfortable '50s rounded neck profile and a 22-fret rosewood fretboard with trapezoid inlays. Epiphone loaded their 1954 Les Paul Standard remake with an Alnico Classic Humbucking pickup in the neck position and a high-output Alnico Classic Plus humbucker in the bridge position. Individual pickup volume and tone controls, and a 3-way select toggle give you command of this tone machine. This limited-edition Epiphone guitar has nickel hardware including precision die-cast tuning machines, and a vintage wraparound stopbar bridge/tailpiece.
Epiphone Ltd Ed 1954 Les Paul Standard Electric Guitar Features:
Style: Single-cutaway Les Paul
Top: Carved maple
Body: Mahogany
Neck: Set mahogany
Scale length: 24-3/4"
Neck profile: '50s rounded
Fingerboard: Rosewood
Fingerboard radius: 14"
No. of frets: 22
Fingerboard inlays: Trapezoid
Nut Width: 1-11/16"
Neck pickup: Alnico Classic humbucker
Bridge pickup: Alnico Classic Plus humbucker Controls: Two Volume, Two Tone, 3-way toggle pickup selector
Hardware: Nickel
Tuners: Precision die-cast
Bridge: Wrap-around Bridge/Stopbar
Finish: Polyurethane
Case: Not Included
Don't miss your chance to own this affordable historic limited-edition.
Its basically the Epi version of the legendary oxblood LP Jeff Beck played (and pictured!) in his highly-acclaimed album Blow By Blow.
(Si, me sirvieron, jajaja.)
No hay de que, lo que necesites.
Un saludo tio.
aupa soy de vitoria, una pregunta, las visto en una tienda de segunda mano bastante conocida? si es asi la guitarra es la que dice el compañero,les paul jeck beck oxbloood,y si tiene la pastilla del puente seymour duncan ,esa guitarra fue mia,por cierto guitarron ,espero que te haya ayudado,un saludo
